Magura Braze On Adapters? Help?
Carlperkins
http://www.tartybikes.co.uk/rim_brake_spares/magura_brazeon_adaptors_and_bolts/c5p11051.html
I will be getting some of these in the next 3-4 days. does anyone know how to put them on? it says braze-on.
but i always thought that brazing steel and aluminium together was one of the hardest things to do??
anyone used these before? if so how did you do it? and what brazing rods do i need to buy?
any help will be immensely appreciated. been looking on google for about an hour and got nowhere.
carl.
you never thought about tap n die???? did it to my koxx levelboss 03 rear brake mounts n workin a treat :D
im buying a second hand frame, which has been stripped, helicoiled, and then stripped again haha.
ill just grind off the 4 bolt mounts and run dual disc,
