Chain Problem
whenever im riding my chain go's tight and slack as the wheel go round and its not the freewheel cos this goe's stupidly slack then tight so im wandering whether i should put a different chain on ebcause the one ive got on now has stretched in one spot any other ideas ?
possible tight spot or your front cog may be out of line, i had this problem and found the spacer was split, replaced it - problem solved
