Nick In Action Posted May 7, 2011 Report Share Posted May 7, 2011 (edited) Someones selling it for $400. Everything on it looks like its from walmart. I'd like to upgrade everything slowly, starting with the brakes. Would a really good Hydraulic rim brake system be compatible with the frame mounts? Thanks http://i54.tinypic.com/fkp2cm.jpg Edited May 7, 2011 by Nick In Action Quote Link to comment Share on other sites More sharing options...
sstein Posted May 7, 2011 Report Share Posted May 7, 2011 Yeah, would be fine but a v brake setup is quite often better. Also (although i only have that crappy pic to go on) it does not look that cheap a setup Quote Link to comment Share on other sites More sharing options...
Nick In Action Posted May 7, 2011 Author Report Share Posted May 7, 2011 Yeah, would be fine but a v brake setup is quite often better. Also (although i only have that crappy pic to go on) it does not look that cheap a setup Great, thank you very much. Quote Link to comment Share on other sites More sharing options...
neilrobson1989 Posted May 7, 2011 Report Share Posted May 7, 2011 Yeah, would be fine but a v brake setup is quite often better. Also (although i only have that crappy pic to go on) it does not look that cheap a setup id prob just get a rear mag front v is fine or if you have the money get a front disc Quote Link to comment Share on other sites More sharing options...
Nick In Action Posted May 7, 2011 Author Report Share Posted May 7, 2011 id prob just get a rear mag front v is fine or if you have the money get a front disc Yeah I thought so as well. I'll have to upgrade them forks n wheel though. dangit Quote Link to comment Share on other sites More sharing options...
ogre Posted May 12, 2011 Report Share Posted May 12, 2011 why? the spec looks prety good, i've used vee brakes for 2 years, and they're awesome... Quote Link to comment Share on other sites More sharing options...
bip Posted May 12, 2011 Report Share Posted May 12, 2011 (edited) Stick with the vees, maybe get a grind and new pads for the rear when you feel the need. Save your money and maybe look into new bars/stem depending on how you get on with the ones in the picture. Also if a basic freewheel is on there at the moment then wait till it dies and get a nice one. Otherwise the bike looks pretty decent. Edited May 12, 2011 by bip Quote Link to comment Share on other sites More sharing options...
max-t Posted May 16, 2011 Report Share Posted May 16, 2011 Thats a good deal for 400 bucks. Quote Link to comment Share on other sites More sharing options...
