Ash-Kennard Posted May 7, 2011 Report Share Posted May 7, 2011 (edited) right, so i bought an echo tr lever the other day, they do not come with the grub screw for bleeding, so i decided to use the one off my old magura, as i bought it as a lever only, there is no hose from the calipers to the lever, so i had to put a magura barbed fitting in. just tried bleeding the brake, and i think the grub screw might be too small, as when its done up it literally just pisses the fluid back out, this means the barbed fitting will be too small, does deng use imperial instead of metric bolts? if this is the case, it is annoying because tarty dont stock echo barbed or echo grub screws. the grub screw im sure i can find one that fits from the local shop, but the barbed fitting, i have no idea where to get one infact looking on tarty, they suggest you just use the magura barbed fitting, so im fine for that i guess, but why is it leaking the grub screw should be the same size as the barb Edited May 7, 2011 by Ash-Kennard Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted May 7, 2011 Author Report Share Posted May 7, 2011 fixed it now, but not sure how, just swapped around the holes on the lever pretty weird it worked but im not complaining... Quote Link to comment Share on other sites More sharing options...
