Sam T Posted May 6, 2011 Report Share Posted May 6, 2011 Hey guys, Right, was out riding earlier and the brake went all shite and slow. I need to get the piston out of the main body, but how do I? Quick reponses would be appricated!! Sam Quote Link to comment Share on other sites More sharing options...
Jamie East Posted May 6, 2011 Report Share Posted May 6, 2011 Needle nose pliers should just pull out, although can be a bit stiff. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted May 6, 2011 Report Share Posted May 6, 2011 If you have a bleed kit; use the pipe that goes into the lever body attached to a compressor or bike pump. But be well careful when pumping as the pressure is stupidly intense and you'll either lose the piston and spring or it will take your eye out. We did this in my uni room and spent the next 30 minutes searching everywhere for it haha. 1 Quote Link to comment Share on other sites More sharing options...
