echoteam9484 Posted May 2, 2011 Report Share Posted May 2, 2011 Im currently using a hope mono trial on the rear of my 20" frame. Im using a +20 adaptor on a 160mm rotor does the adaptor make any difference to the performance ? the bleed it ace Its just lacking hold and bite....it works well but not as good as ones ive ridden. Whats the best rotor to use ? thanks Quote Link to comment Share on other sites More sharing options...
echoteam9484 Posted May 3, 2011 Author Report Share Posted May 3, 2011 bump Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted May 3, 2011 Report Share Posted May 3, 2011 +20 on a 160mm rotor?? Eh? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted May 3, 2011 Report Share Posted May 3, 2011 +20 on a 160mm rotor?? Eh? #5 caliper. Yes, a +20 adaptor makes the brake feel a bit poo. Quote Link to comment Share on other sites More sharing options...
Nyczek Posted May 3, 2011 Report Share Posted May 3, 2011 Maybe pads need to reach ... try to wet pads by wather, and what pads you use, standard organic ? Quote Link to comment Share on other sites More sharing options...
echoteam9484 Posted May 4, 2011 Author Report Share Posted May 4, 2011 #5 caliper. Yes, a +20 adaptor makes the brake feel a bit poo. Would it make the brake work worse ? Quote Link to comment Share on other sites More sharing options...
Nyczek Posted May 5, 2011 Report Share Posted May 5, 2011 (edited) Would it make the brake work worse ? All adaptor, and for me all aluminium bolts make disc break more flexible/extensible ( sorry can't find word ) Edited May 5, 2011 by Nyczek Quote Link to comment Share on other sites More sharing options...
