Frame Welding
BradJohnson
hi a mate of mine has broken his frame near the bottom braket on one side, his frame is made from aluminium, will welding the frame fix it ? or is there anyother way to fix it ?
New weld or weld a plate on to it would do the job.
thanks alot mate, by any chance would you know how much it would cost if he takes it to a professional welder ?
Not sure. All i know is that Ali welders charge more. Best bet would be to go onto Thompson Local and look for a fabrication or engineering company within your area. (Y)
Yeh, get it too an engineering firm, but tell them not to get it too hot otherwise it will be weaker than it is already :)
Needs to be hot enough though, other wise it wont hold very well. Best bet is to try and find someone who's experienced and knows what there doing. Tis what i did when my rockman cracked
