Magura Lever Exploded!
Themistoklidis
My brake lever exploded while i was riding today!The small bolt on the lever disappeared and left me with a lousy rear brake and contaminated front drisk pads as the brake liquid dripped on the disk brake!!!The question is what do you suggest i bleed it with?brake fluid or bath bleed(i have never bled maguras before or another hydraylic brake)?Another solution would be to get rid of the maggies and get a Vee...Do you think its a good idea or the maggie is better?
Thanks,Themis.
Edited by BikeTrialsInGreece
dont use car grade brake fluid!!! lol
if your going too use oil go for either the magura brand (expensive) or find out the viscosity(how thick it is) of the magura oil and find an alternative.
ive never used water personnally but i beleive it is a good alternative.
just make sure you have a nice size seringe so you can punp it through until there are no air bubbles coming out the other end.
:lol: i ment oil like royal blood or phluid.I Will search for some bleeding guides and decide next because i have heard more than enough good words about water bleed!
get a vee
Even with the V adaptors it will be better than the magura?Maybe ill give it a go and see what happens :)
