cyprusactive Posted April 28, 2011 Report Share Posted April 28, 2011 On a Yamaha 250 two stroke we are pretty certain we have a broken piston ring. The garage says he can change it without taking the head off as he can remove the barrel bolts and slide the barrel and head up and off. The head gasket is around £50 and he says it will save disturbing it does that sound right? It is oldish and we think that there will be little bore damage. Quote Link to comment Share on other sites More sharing options...
forteh Posted April 28, 2011 Report Share Posted April 28, 2011 On a Yamaha 250 two stroke we are pretty certain we have a broken piston ring. The garage says he can change it without taking the head off as he can remove the barrel bolts and slide the barrel and head up and off. The head gasket is around £50 and he says it will save disturbing it does that sound right? It is oldish and we think that there will be little bore damage. Unfortunately this is a bicycle trials forum so youre not likely to get a fully informed reply However what he says does make sense, if there is any bore damage then you will have to bite the bullet and get it honed/bored/plated/lined; all depends on how long its run with the broken ring (assuming youre correct with the diagnosis). If its a TY250 it might be worth giving muel a PM as he has had a couple of TYs in the past and currently has a 175 iirc Quote Link to comment Share on other sites More sharing options...
am-i-bothered Posted April 28, 2011 Report Share Posted April 28, 2011 On a Yamaha 250 two stroke we are pretty certain we have a broken piston ring. The garage says he can change it without taking the head off as he can remove the barrel bolts and slide the barrel and head up and off. The head gasket is around £50 and he says it will save disturbing it does that sound right? It is oldish and we think that there will be little bore damage. Why dont you just do it yourself? two strokes are so easy to work on! Just take it apart and see whats going on and go from there Quote Link to comment Share on other sites More sharing options...
mototrials90 Posted April 28, 2011 Report Share Posted April 28, 2011 dont cheap out get it all done mate Quote Link to comment Share on other sites More sharing options...
