onza1 Posted April 23, 2011 Report Share Posted April 23, 2011 Hi all Just converted to singlespeed and need a new chain. Not sure wether I need a 3/32 or a 1/8 the rear sprocket is 20t the ones from superstar components. Help appreciated Quote Link to comment Share on other sites More sharing options...
onza1 Posted April 23, 2011 Author Report Share Posted April 23, 2011 Come on fellas what chain do I need Quote Link to comment Share on other sites More sharing options...
smithy83 Posted April 23, 2011 Report Share Posted April 23, 2011 a good chain is the kmc 510hx or the trialtech as they are the same chain. they do it in two versions to suite you sprocket im running the 1/8th on 18 by 12 gearing and never had any problems at all.highly recommend. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 23, 2011 Report Share Posted April 23, 2011 1/8" is slightly wider than the 3/32" (obviously) so if you need the extra width then go for that one, but the shorter pins on the 3/32" chain will generally make it a little stonger. Check the thickness of your sprocket (or throw a link up) and go from there I've only run 3/32" chains for the past however many years with very few issues. Quote Link to comment Share on other sites More sharing options...
onza1 Posted April 23, 2011 Author Report Share Posted April 23, 2011 So I can get away with either then ? Also not sure wether to have a go with a half link as I won't be using a tensioner maybe the half link thus on rock n roll bikes what do you think ? Sorry can't get links to products as using the iPod Cheers Quote Link to comment Share on other sites More sharing options...
