Manus-Rider Posted April 21, 2011 Report Share Posted April 21, 2011 Hello, i have just bought a onza ice frame and iam looking to get a new wheelset and i was woundering is there any hubs that will not fit the frame? Due to only viz and onza hubs fitting the 320? Thanks so much for any help 1 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 22, 2011 Report Share Posted April 22, 2011 Are you gong to be running rear disc or rim brake? Quote Link to comment Share on other sites More sharing options...
Manus-Rider Posted April 22, 2011 Author Report Share Posted April 22, 2011 Are you gong to be running rear disc or rim brake? iam going to be running rear disc and iam looking at hubs such as rockman bub and tryall h 1 Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 23, 2011 Report Share Posted April 23, 2011 In that case you will need V!Z or Onza if you don't want to have to do some bodging Quote Link to comment Share on other sites More sharing options...
CalopS Posted April 23, 2011 Report Share Posted April 23, 2011 (edited) If its anything like the Onza Comp frame I just used some spacers to move the frame away from the disc rotor. Doesn't take much bodging! EDIT: I just remembered, I used some snail cams as spacers Edited April 23, 2011 by CalopS Quote Link to comment Share on other sites More sharing options...
Manus-Rider Posted April 23, 2011 Author Report Share Posted April 23, 2011 If its anything like the Onza Comp frame I just used some spacers to move the frame away from the disc rotor. Doesn't take much bodging! EDIT: I just remembered, I used some snail cams as spacers Thanks adam and calops 1 Quote Link to comment Share on other sites More sharing options...
