LROB87 Posted April 19, 2011 Report Share Posted April 19, 2011 forgive my stupidity lol Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 19, 2011 Report Share Posted April 19, 2011 Won't work unfortunately. Freewheels screw on so you need a hub with threads Assuming you were looking at the Onza because it best fits your budget, one of these would do the job nicely: http://www.tartybikes.co.uk/135mm_fixed_hubs/trialtech_race_sealed_rear_hub/c21p11423.html http://www.tartybikes.co.uk/135mm_fixed_hubs/atomz_premier_screw_on/c21p11380.html Don't worry - it's all pretty straight forward once you get your head around it all! Quote Link to comment Share on other sites More sharing options...
LROB87 Posted April 19, 2011 Author Report Share Posted April 19, 2011 was looking at an echo this seems like the exact same as on tarty but £24 cheaper would this be ok? http://www.rocknrollbikes.com/trials/hubs/onza-rear-sealed-trials-hub-black-240-grams.html Won't work unfortunately. Freewheels screw on so you need a hub with threads Assuming you were looking at the Onza because it best fits your budget, one of these would do the job nicely: http://www.tartybikes.co.uk/135mm_fixed_hubs/trialtech_race_sealed_rear_hub/c21p11423.html http://www.tartybikes.co.uk/135mm_fixed_hubs/atomz_premier_screw_on/c21p11380.html Don't worry - it's all pretty straight forward once you get your head around it all! Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 19, 2011 Report Share Posted April 19, 2011 Hold up, are you on a mod (20") or a stock (26")? If you're on a stock (middleburns and looking at the 135mm Onza hub before) then no, that looks to be a 116mm rear hub which is mod spacing. There's no description so don't take that as gospel, but I'm fairly sure that'll be the case. If it is 135mm then it'll be fine, but since this is Onza's 135mm spaced screw on hub I'm pretty sure the one you linked to is too thin. Quote Link to comment Share on other sites More sharing options...
LROB87 Posted April 19, 2011 Author Report Share Posted April 19, 2011 cheers, just noticd its you again Luke haha put me on a retainer im gonna have to start paying you Yep, that'd do the job just fine Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 19, 2011 Report Share Posted April 19, 2011 Yeah, you might want to check the edit after I actually thought about what I was looking at Quote Link to comment Share on other sites More sharing options...
LROB87 Posted April 19, 2011 Author Report Share Posted April 19, 2011 you're probably right that would explain the price difference! i ride a 26" hawyes so is 135mm right? Yeah, you might want to check the edit after I actually thought about what I was looking at Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 19, 2011 Report Share Posted April 19, 2011 Yep. Quote Link to comment Share on other sites More sharing options...
