kips Posted April 19, 2011 Report Share Posted April 19, 2011 Built a new bike for myself. Feels great. More pics: https://picasaweb.google.com/kristaps.skudra/2011_04_trialsmaster_net_X_ray_26# Frame: X Ray Fork: X Ray HS33 Handlebar: Born Carbon Stem: Born 26" Grips: Trialtech Headset: Hope Brakes: Magura HS33, magura clamps Brake pads: Monty F. rim: Trialtech R. rim: Trialtech single wall F. hub: Monty R. hub: Because Spokes: Sapim F. tire: Schwalbe Nobby nic 2.1 R. tire: Try All sticky lite Bottom bracket: Born Cranks: Neon CNC 172 mm Pedals: Trialtech Sport Magnesium Rockring: Neon Conquer Freewheel: Monty 18 Sprocket: Trialtech 15t Snail cams: Neon Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted April 19, 2011 Report Share Posted April 19, 2011 Not to keen on the downtube graphics but it looks tidy Quote Link to comment Share on other sites More sharing options...
Sponge Posted April 19, 2011 Report Share Posted April 19, 2011 Pretty nice! Am I right in seeing that the front rim still has a sharp grind going? If so, how is that kind of front HS33 set up doing compared to a disc? I haven't used front Mag in yeeeears and definitely not on rear-mounted forks and a grind! So I'm curious what kind of performance to expect Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted April 19, 2011 Report Share Posted April 19, 2011 Pretty nice! Am I right in seeing that the front rim still has a sharp grind going? If so, how is that kind of front HS33 set up doing compared to a disc? I haven't used front Mag in yeeeears and definitely not on rear-mounted forks and a grind! So I'm curious what kind of performance to expect There bloody brilliant if you get the right pads. i still havent found a pair that i like though Quote Link to comment Share on other sites More sharing options...
