dann2707 Posted April 13, 2011 Report Share Posted April 13, 2011 Right. Had enough of my unbranded BMX chain giving me problems. Just snapped on me whilst pedalling smoothly, nearly went right over the bars haha. Because i'm using a crappy non branded cheapy one, is this the reason why I can't get my brakes set up perfectly and needing a half link to make it the right size? Next question, which one do you reccomend and know that will be the right length for my Onza Comp 20" running an 18 tooth SL freewheel and 12 tooth rear fixed sprocket? Links would be great. Thanks. Dan Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 13, 2011 Report Share Posted April 13, 2011 Trialtech Lite / Z610hx From Here Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 13, 2011 Author Report Share Posted April 13, 2011 Is it 3/32" i'm after? What do the sizes even refer to? Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 13, 2011 Report Share Posted April 13, 2011 Im 99.9% sure you will be fine. But IIRC that's the pitch measurement for the chain? Quote Link to comment Share on other sites More sharing options...
Mark W Posted April 13, 2011 Report Share Posted April 13, 2011 The pitch is the same, it's just the actual widths. So 3/32" is the usual MTB/geared size, and 1/8" is the BMX size. A 3/32" should do you fine on your bike as long as you don't have something like a Halo sprocket on the rear. But yeah, Z510HX/Z610HX fo lyf. Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted April 13, 2011 Report Share Posted April 13, 2011 The pitch is the same, it's just the actual widths. So 3/32" is the usual MTB/geared size, and 1/8" is the BMX size. A 3/32" should do you fine on your bike as long as you don't have something like a Halo sprocket on the rear. But yeah, Z510HX/Z610HX fo lyf. I knew id get it wrong!! Quote Link to comment Share on other sites More sharing options...
dann2707 Posted April 13, 2011 Author Report Share Posted April 13, 2011 Consider my order placed Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted April 13, 2011 Report Share Posted April 13, 2011 Z610 on both my bikes, havent snapped one yet, compared to about 4 kool chains i snapped Quote Link to comment Share on other sites More sharing options...
