Mini 6 Speed Freewheel Caassettes?
LROB87
Freewheel cassette, as in a screw on cassette with built in freewheel?
You might be able to get one from a local dodgy bike shop, but I don't think the freewheels in them are any good.
Otherwise if you're just after a 6 speed cassette, you can always buy a bigger one and chop it up a bit, I did that to run two gears.
Only problem is if you buy a 9 speed cassette let's say and cut it up, the spacers that came with it will only work with a 9 speed shifter, unless you get a thumb shifter.
i've got a 8 speed cassette and shifter on atm so the shifter will still work if i take 2 cogs off? i dont have any spacers though
Yes just make sure the limits screws are adjusted on the mech, it will work but you will have some left over clicks on shifter, not real problem
how will i know when its adjusted, havent don this crap for years lol
