Marino
Martin Direske
I'm currently on a Marino. Well, actually I switch between two frames as one of them is allways cracked or something (So quite often one is in use whereas the other one gets welded :unsure:)
The raw one is the same as the green one since I just sprayed it during the last barbecue-session ^_^
Frame: Marino 24" with a mixture of Inspired/24UK geo
Forks: Echo Urban
Headset: Cane Creek S8
Stem: BBB 70mm/35°
Bars: Trialtech HighRisers
Grips: Trialtech foam
Front brake: BB7/185mm Avid G2/linear slic/XTR lever
Front wheel: RhinoLite on Corratec hub+Holyroller
BB: Truvativ GigaPipe DH
Cranks: 160mm MOE
Rockring: Neon
Freewheel: Echo SL steel 18T
Pedals: Wellgo
Chain: Koolchain
Tensioner: Selfmade 74 Kingz
Rear wheel: Spank Stiffy on DMR Revolver hub/15T sprocket/Holyroller
Rear brake: Shimano arms/Shimano XTR Carbon booster/linear slic cable/XTR lever/Coust CNC pads
Seating: Inspired seat/Salt pivotal/mankind seat clamp
The green frame looks amazing, also whats your back brake like and how much was it?
It actually turned out quite good in comparison to what usually happens when I paint something on my own :D
It's not even lacquer, it's graffity B)
Well, I'ver never used hydraulic brakes again since I've first used a Vee with a trialsy setup :)
Current brake performance can be found here.
It's not the price but the fact that some of those parts are hard to get.. it took some time to get all components I desired (especially the XTR booster. Check Ebay frequently is the only chance you have)
I just sold it due to financial issues. It was just stupid to abuse a 300€ frame - in case I would have broken it I would have been in a crisis lol.
So I sold it and picked up the Marino from a friend of mine for free. Win-Win as it feels just as good apart from the "prestige" :P
