thewoomaster Posted April 11, 2011 Report Share Posted April 11, 2011 (edited) Hey guys, Well i got a rear maggie with phat pads, when i tap it will hold but on pre-loading it don't i can roll the rear wheel back, it will even roll back with little movements it just dont have that bite no more. I have sanded the pads, cleaned the rim, put new oil in (twice to make sure no air etc) also set them up to many times with no joy. Pads have life left on them. Help , Edited April 11, 2011 by thewoomaster Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted April 11, 2011 Report Share Posted April 11, 2011 Phat pads - thats your problem Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 11, 2011 Report Share Posted April 11, 2011 Bleed your brakes with water using Revolvers Bath Bleed guide found in his signiture (Do a search for him) Grind your rim! Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted April 11, 2011 Author Report Share Posted April 11, 2011 (edited) Will try new pads but phat pads were mint, may just a refil will sort it? smooth rim no grind, water a no go(Y) Edited April 11, 2011 by thewoomaster Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 11, 2011 Report Share Posted April 11, 2011 Will try new pads but phat pads were mint, may just a refil will sort it? smooth rim no grind, water a no go(Y) Thats why I said Grind and why refuse to water bleed? Both of those things will improve your brake 10x. Phat's are designed for a grind, of course they're going to be shit on smooth. 1 Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 11, 2011 Report Share Posted April 11, 2011 Maybe try a booster too. Mind, you can get an angle grinder for the price of a booster, and a grind is likely to solve your problem better than a booster. Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted April 11, 2011 Report Share Posted April 11, 2011 Thats why I said Grind and why refuse to water bleed? Both of those things will improve your brake 10x. Phat's are designed for a grind, of course they're going to be shit on smooth. +1 Most top end/decent pads are designed for ground rims.... Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted April 12, 2011 Author Report Share Posted April 12, 2011 (edited) Thats why I said Grind and why refuse to water bleed? Both of those things will improve your brake 10x. Phat's are designed for a grind, of course they're going to be shit on smooth. Phat pads are can be use for both fella. Have used them for a year on smooth with no probs what so ever. ok so why only now they dont work?? Now water cost me a new maggie so why would i do that again , Edited April 12, 2011 by thewoomaster Quote Link to comment Share on other sites More sharing options...
Martin Reynolds Posted April 12, 2011 Report Share Posted April 12, 2011 Phat pads are can be use for both fella. Have used them for a year on smooth with no probs what so ever. ok so why only now they dont work?? Now water cost me a new maggie so why would i do that again , You oviously did it wrong Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 12, 2011 Report Share Posted April 12, 2011 Ofc phatpads can be used for both but they're designed for a grind. Regarding the water bleed you most likely got a sticky piston and instead of simply lubing it up you got rid of it. Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted April 12, 2011 Author Report Share Posted April 12, 2011 Ofc phatpads can be used for both but they're designed for a grind. Regarding the water bleed you most likely got a sticky piston and instead of simply lubing it up you got rid of it. Never fought of that will try lubing the pistons.. not go down the grind or smooth path Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 12, 2011 Report Share Posted April 12, 2011 Never fought of that will try lubing the pistons.. not go down the grind or smooth path I mean you got the sticky piston because of the water, with an oil bleed it's rare to get one. I give up. Who else wants to help? Quote Link to comment Share on other sites More sharing options...
thewoomaster Posted April 13, 2011 Author Report Share Posted April 13, 2011 (edited) well new pads seemed to have worked, ta for trying to help. I did'nt know you could only get that with a water bleed but checked it out so thks Edited April 13, 2011 by thewoomaster Quote Link to comment Share on other sites More sharing options...
nb88 Posted April 13, 2011 Report Share Posted April 13, 2011 Brake booster, Decent pads, Decent bleed (water is best), Grind on a good rim, Pads set up square to the rim, Strong brake finger? = Perfect brake Quote Link to comment Share on other sites More sharing options...
