Azarathal Posted April 8, 2011 Report Share Posted April 8, 2011 (edited) Hey guys, recently bought a rear hope mono trials for my Zhi Z3. It seems like the tabs on the caliper are too short to bolt in? Heres a pic of the brake I bought and a close up of the disk mount on a Zhi Z3. Edited April 8, 2011 by Azarathal Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 8, 2011 Report Share Posted April 8, 2011 Wrong caliper. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 8, 2011 Author Report Share Posted April 8, 2011 Cheers, is it a #3 or #5? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 8, 2011 Report Share Posted April 8, 2011 You have 5, need 3, or one of these in +20: http://www.tartybikes.co.uk/disc_brake_spares/hope_iso_disc_brake_adaptor/c110p23.html Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 8, 2011 Author Report Share Posted April 8, 2011 What would you recommend then? Buying the Adapter or trying to find a trade? Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 8, 2011 Report Share Posted April 8, 2011 Get the adaptor. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 8, 2011 Author Report Share Posted April 8, 2011 Get the adaptor. I guess this is the easiest route to take, cheers guys. Quote Link to comment Share on other sites More sharing options...
Revolver Posted April 8, 2011 Report Share Posted April 8, 2011 Easiest, and most versatile. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 12, 2011 Author Report Share Posted April 12, 2011 Wrong caliper. Wrong adaptor. 1: I can't even get it to bolt onto my frame as one of the adaptors holes 'Doesn't quite reach' 2: Only two of the holes on the adaptor are threaded so if I filed my frames disc tab slightly to make it fit I still couldn't bolt my brake on. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 12, 2011 Report Share Posted April 12, 2011 the two threaded holes are the ones that take the bolts to the frame. So bolt goes through the frame to the adaptor. The two umthreaded holes are what the calliper bolts onto. So bolts go through the non threaded holes in the adaptor, and into the threaded holes in your calliper. Tighten up, boom. Correctly placed calliper. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 12, 2011 Author Report Share Posted April 12, 2011 Yeah I worked that out after my post, the problem now is that the mount itself seems to be in the way so the bolt holes don't line up, going to swap front and rear clipers, front is a #3 Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 12, 2011 Report Share Posted April 12, 2011 Yeah I worked that out after my post, the problem now is that the mount itself seems to be in the way so the bolt holes don't line up, going to swap front and rear clipers, front is a #3 so the adaptors threaded holes dont line up with the holes in the frame? Would seem so if your current avid adaptor fits. Something wrong with the adaptor. Before you swap callipers over, bolt the front onto the rear before you detach anything to see if its right Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 12, 2011 Author Report Share Posted April 12, 2011 Yeah I'm going to check the front caliper before I swap them. The picture with the avid brake on is an example of the mount on my bike. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted April 12, 2011 Report Share Posted April 12, 2011 Yeah I'm going to check the front caliper before I swap them. The picture with the avid brake on is an example of the mount on my bike. reallised the pic was an example just after I posted. I hope you get it sorted mate, theyre brilliant brakes once set up correctly. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 12, 2011 Author Report Share Posted April 12, 2011 The #3 caliper doesn't fit either. don't really want to file / grind my frame or new adapter. Any other options? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted April 13, 2011 Report Share Posted April 13, 2011 Someone didn't design that frame very well then Only option would be a different brake I guess, if that even fits... Quote Link to comment Share on other sites More sharing options...
Azarathal Posted April 14, 2011 Author Report Share Posted April 14, 2011 I found theres a 1mm raised area. I'll file it down. Thanks for everyones help. Quote Link to comment Share on other sites More sharing options...
