How To Measure Bottom Brackets
BurlyBox
ive just got my first trials bike and i got it pretty cheap but it needed some repairs and one of them is the bottom bracket because the axle is literally flaking away and has wrecked the left crank as well. the problem is i have no idea how to measure it and what part of it needs to be measured.
Can anyone offer any advice? also its for an Onza T-Pro 2005 in case someone already knows.
Thanks, Jake
can i fit 127.5 or not then? because thats the size ive found more often
Yes you can. 127.5 is 0.25mm shorter on each side than a 128mm you wont notice the difference. Are you replacing the complete crankset or just the one that is ruined? If you are replacing the cranks and bottom bracket, I would highly recommend getting an ISIS bottom bracket and ISIS cranks.
pretty much yeah im getting a complete new crankset as the left crank wobbled and destroyed the bottom bracket and the crank so i thought id replace the lot. i might go for the ISIS parts though but i know they are a little more expensive. are ISIS parts much better than square? and also what about 127mm? would that work? (sorry about all of the questions)
Edited by BurlyBox
