madmacca Posted March 30, 2011 Report Share Posted March 30, 2011 (edited) water bleed has killed my magura lol i drained the oil out of my magura 07-10 model and bathbled it using the guide was spot on went out last night worked a treat got home put bike away and thismorning the leaver jammed as soon as i pulled lever in and wont return iv took it apart checked piston when finally got it out took 80psi through a footpump to get it unjammed and out i did it in bath so the piston would react like a bullet and be slown down as soon as left the chamber checked it cleaned it n put bk togeather but just doing the same i evan stretched the spring but nothing! It's fubard well looks like il be buyin a new piston kit n oil & bleed kit instead of wheels. atb paul Edited March 30, 2011 by madmacca Quote Link to comment Share on other sites More sharing options...
JD™ Posted March 30, 2011 Report Share Posted March 30, 2011 Just sand down the piston and chuck it back in, it happens to them all in time 1 Quote Link to comment Share on other sites More sharing options...
matt.price Posted March 30, 2011 Report Share Posted March 30, 2011 Just sand down the piston and chuck it back in, it happens to them all in time just take the o-ringoff before hand. i did the above and i sanded my o-ring and had to get a new one Quote Link to comment Share on other sites More sharing options...
dann2707 Posted March 30, 2011 Report Share Posted March 30, 2011 Exact same thing happened to me. Take quite a bit off the piston, so that it falls in and out of the cylinder with ease. Any sign of friction and it getting even slightly stuck take more off. I did this 3 times as I thought I had removed enough but I actually hadn't. Works perfect now with water. It happens due to there obviously being no lubricity inside the cylinder with just water. Quote Link to comment Share on other sites More sharing options...
madmacca Posted March 30, 2011 Author Report Share Posted March 30, 2011 sweet il give it ago now cheers peep's Quote Link to comment Share on other sites More sharing options...
madmacca Posted March 30, 2011 Author Report Share Posted March 30, 2011 well took apart and sanded it put bk togeather and now feels brand new again cheers & atb paul Quote Link to comment Share on other sites More sharing options...
