Aidan97 Posted March 28, 2011 Report Share Posted March 28, 2011 when tight are all bb's supposed to be flush with the frame? Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 28, 2011 Report Share Posted March 28, 2011 There often seems a little variety in BB shells, else they'd fit better. I'd tighten the driveside one flush, and if the other one pokes out of the shell, that's ok. But you can use this to adjust a little bit if your cranks are rubbing or such like. Quote Link to comment Share on other sites More sharing options...
Aidan97 Posted March 28, 2011 Author Report Share Posted March 28, 2011 There often seems a little variety in BB shells, else they'd fit better. I'd tighten the driveside one flush, and if the other one pokes out of the shell, that's ok. But you can use this to adjust a little bit if your cranks are rubbing or such like. by the driveside do you mean the side were the freewheel is? Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted March 28, 2011 Report Share Posted March 28, 2011 yea mine sticks out loads on the non drive side still works the same Quote Link to comment Share on other sites More sharing options...
Aidan97 Posted March 28, 2011 Author Report Share Posted March 28, 2011 yea mine sticks out loads on the non drive side still works the same good I thought I was the only one Quote Link to comment Share on other sites More sharing options...
