26" Onza 2010
JDStrials
i am considering buying the onza hitman or the Onza Cleaner. the cleaner has magura rear and disk brakes where as the hitman has v brakes.
the cleaner has better cranks and pedals and the rims are drilled out.
is it worth an extra £100 for all of these things
thanks a lot jack
Where you looking at buying from??
EDIT: Actually just spotted your older thread. I'd say it is worth it as I personally prefer maguras to v's but saying that there's certain people on here that swear by a good set of well setup v brakes.
If it was me though I'd not bother with the Onza and go for a MAD Phase 1.2 which you can pick up for about £250. The frame is much better for upgrading as it's the very same that the MAD team riders use as seen here http://www.trials-fo...nett-in-london/ whereas with the onza you'll be looking at swapping all the components AND the frame as you progress!
Edited by isitafox
  • Like 1
Thanks
