George6512 Posted March 27, 2011 Report Share Posted March 27, 2011 Are monty splitters any good and do they inprove your brakes and how do you bleed them ? cheers Quote Link to comment Share on other sites More sharing options...
Sam T Posted March 27, 2011 Report Share Posted March 27, 2011 You bleed them like normal George. Heard they're a pain in the ass to fit though! Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 27, 2011 Report Share Posted March 27, 2011 They can be a pain in the arse to fit if your a bit rough as it's not hard to snap the ends off but if you can fit them ok they're great, especially for routing the hose through the frame. And it means there's no crossover to accidentally snap either! Quote Link to comment Share on other sites More sharing options...
Danny Posted March 27, 2011 Report Share Posted March 27, 2011 Bleeding is a bit different as you need to bleed each slave separately. Note you also need a pair of slaves both with a bleed screw rather than a normal pair (M6/M6 rather than M6/M8). Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 27, 2011 Report Share Posted March 27, 2011 Bleeding is a bit different as you need to bleed each slave separately. Note you also need a pair of slaves both with a bleed screw rather than a normal pair (M6/M6 rather than M6/M8). Not necessarily, if you buy a M8 bolt and cut it down to use essentially as a 2nd bleed bolt you can stick with the original cylinders. Quote Link to comment Share on other sites More sharing options...
George6512 Posted March 27, 2011 Author Report Share Posted March 27, 2011 Ahh cheers guys i was just wondering anyway and knowing me i proberly would end up snapping the barbs. =P Quote Link to comment Share on other sites More sharing options...
bella Posted March 27, 2011 Report Share Posted March 27, 2011 Let me know how you get on I would like to do this to my rear brake Quote Link to comment Share on other sites More sharing options...
George6512 Posted March 27, 2011 Author Report Share Posted March 27, 2011 Let me know how you get on I would like to do this to my rear brake I dont think im going to get one i was just wondering thats all. =P Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted March 28, 2011 Report Share Posted March 28, 2011 you don't need to change slaves or cut bolts or owt like that. if your bothered about the pressures being equal, cut the line going the m8 side a tad shorter. thats what I did with mine but I snapped the prong being to rough. IMO it shouldn't have prongs but 3 tapped M6 holes so you screw in barbs like in slaves. or is it just me? Quote Link to comment Share on other sites More sharing options...
thispartisrequired Posted March 28, 2011 Report Share Posted March 28, 2011 IMO it shouldn't have prongs but 3 tapped M6 holes so you screw in barbs like in slaves. or is it just me? I agree with that, i have a monty splitter, unfitted but i can see it shearing off as i try to fit it, might a threaded job just in case :/ Quote Link to comment Share on other sites More sharing options...
