davidbarr Posted March 22, 2011 Report Share Posted March 22, 2011 Right guys, Helicoiled one of my hs33 mounts at the weekend and i have a problem. Everything was fine, but i took my clamps off to put my new slaves on and when i started tightening the bolt back up it started spinning (just as if the thread has stripped). I took the bolt out and the helicoil insert had just popped out. I re-tapped the mount - tried again, and had the same problem. Tried some glue but still, no joy. Any ideas whats wrong? Thanks Quote Link to comment Share on other sites More sharing options...
sstein Posted March 22, 2011 Report Share Posted March 22, 2011 Right guys, Helicoiled one of my hs33 mounts at the weekend and i have a problem. Everything was fine, but i took my clamps off to put my new slaves on and when i started tightening the bolt back up it started spinning (just as if the thread has stripped). I took the bolt out and the helicoil insert had just popped out. I re-tapped the mount - tried again, and had the same problem. Tried some glue but still, no joy. Any ideas whats wrong? Thanks did you use the right size drill bit and tap? are the threads ok? did you remove the tang? Quote Link to comment Share on other sites More sharing options...
davidbarr Posted March 23, 2011 Author Report Share Posted March 23, 2011 did you use the right size drill bit and tap? are the threads ok? did you remove the tang? yes, did all of these. Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted March 23, 2011 Report Share Posted March 23, 2011 If the thread you tapped for the coil to sit in was slack in any way the insert may come loose. Try with a dab of Threadlock (the permanent stuff) or a little superglue to stop it freeing up so easily Quote Link to comment Share on other sites More sharing options...
