colo157 Posted March 22, 2011 Report Share Posted March 22, 2011 hey, the thing is t,hat I have an avid bb7 in my bike, it doesn´t lock so well, I did the thing of puting water in it and it worked, but I want to know if is it there some other trick to make it work better; my avid has the methalic pads, I use it whith the avid SD7 lever, and my disc is the 180mm one, and is well set, if it helps for the information and please vote so I can be full member plese! lots of thanks from Argentina's biketrial colo Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted March 22, 2011 Report Share Posted March 22, 2011 Rub your pads lightly with sandpaper to take off any bad things on it and clean your disc with a disc brake cleaner. Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted March 22, 2011 Report Share Posted March 22, 2011 How long have you been using it for? Have you given it time to bed in? Might be contaminated, in which case get some brake cleaner or bake it in an oven Quote Link to comment Share on other sites More sharing options...
