Gaz96 Posted March 20, 2011 Report Share Posted March 20, 2011 Before I install my brake I was wandering if its worth filing the mounts like in the TNN engineering advanced hs33 set up video? Does it make much difference? And should I only do it if the brakes dont line up square, or should I do it before I even try fitting them? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 20, 2011 Report Share Posted March 20, 2011 If you have the time, and the tools, you have nothing to loose. It will make your brakes easier to set up, they will be set squarely and in turn your brake performance should increase. Only takes about 5 - 10 mins Quote Link to comment Share on other sites More sharing options...
Gaz96 Posted March 20, 2011 Author Report Share Posted March 20, 2011 Thanks, I've got a file lying about so I will probably give it a bash Quote Link to comment Share on other sites More sharing options...
Crazy Drummer Posted March 21, 2011 Report Share Posted March 21, 2011 yeah i would file them. this video explains it all Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted March 21, 2011 Report Share Posted March 21, 2011 He referred to that video anyway. Quote Link to comment Share on other sites More sharing options...
Gaz96 Posted March 21, 2011 Author Report Share Posted March 21, 2011 Ye, that video is where I first seen the idea of filing the mounts a while back Quote Link to comment Share on other sites More sharing options...
kaybs41282 Posted March 23, 2011 Report Share Posted March 23, 2011 Does it make a big difference when setting the brakes up...? Mine keep misaligning when I nip up the bolts so I wonder if I need to do it Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted March 28, 2011 Report Share Posted March 28, 2011 Yes. Quote Link to comment Share on other sites More sharing options...
bella Posted March 28, 2011 Report Share Posted March 28, 2011 Never thought of that my rear brakes always been crap so I think this is well worth a go. Quote Link to comment Share on other sites More sharing options...
