Duncy H Posted March 17, 2011 Report Share Posted March 17, 2011 (edited) My bikes been stood for a while or had little use over winter. I run dual 05+ maguras and they both started to become a bit stiff, i've had both pistons out and lubed them both, the front has been stck before but is unsmooothly working atm. However the rear is well and truly stuck at the bottom of the piston. I've tryed using an air compressor and a syringe to force it out with no luck. Anyone got anymore tips? Edited March 17, 2011 by Duncy H Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 17, 2011 Report Share Posted March 17, 2011 Track pump? We once had to get one up to 140psi before it started to move... Quote Link to comment Share on other sites More sharing options...
trials owns Posted March 17, 2011 Report Share Posted March 17, 2011 (edited) My bikes been stood for a while or had little use over winter. I run dual 05+ maguras and they both started to become a bit stiff, i've had both pistons out and lubed them both, the front has been stck before but is unsmooothly working atm. However the rear is well ans truly stuck at the bottom of the piston. I've tryed using an air compressor and a syringe to force it out with no look. Anyone got anymore tips? undo the grub screw and push a spoke or similar up. when it havend to me the piston just leaked a week later. EDIT sory that was for hs11 lol Edited March 17, 2011 by trials owns Quote Link to comment Share on other sites More sharing options...
Duncy H Posted March 17, 2011 Author Report Share Posted March 17, 2011 Track pump? We once had to get one up to 140psi before it started to move... I haven't got a track pump unfortunately I think my compressor goes up to 90 ish. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 17, 2011 Report Share Posted March 17, 2011 Borrow one, hehe. Quote Link to comment Share on other sites More sharing options...
Duncy H Posted March 17, 2011 Author Report Share Posted March 17, 2011 Borrow one, hehe. I'm already on it like gromit How did you go about sealing it/ensuring it was a tight fit? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 17, 2011 Report Share Posted March 17, 2011 Magura bleed hose Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 17, 2011 Report Share Posted March 17, 2011 I have a track pump that can go up to 2000psi if it needs that kind of pressure. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 17, 2011 Report Share Posted March 17, 2011 Boiling water, and an old spoke got my 04 one out . Why not try a syringe? Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 17, 2011 Report Share Posted March 17, 2011 The syringe is a push fit, they always pop off if you put proper pressure down them. Quote Link to comment Share on other sites More sharing options...
Duncy H Posted March 18, 2011 Author Report Share Posted March 18, 2011 I've had it out and stuck a few times again. It just doesn't want to spring back at all when it's in there, what can i do to solve this? Is it time for a new o-ring/seal on the piston? Or is it time to put the lever to bed? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted March 18, 2011 Report Share Posted March 18, 2011 Ideally you would lathe down the piston until it fits... but sandpaper/filel would do the job if you are careful. Take the seals off first though! Quote Link to comment Share on other sites More sharing options...
James Quigley Posted March 18, 2011 Report Share Posted March 18, 2011 This happened to a lever of mine, no matter what I did whenever I put the piston back into the lever it got stuck. Left it in the bottom of a toolbox for a year, looked at it the other night and it had a lovely sharp springy action. I realise this doesn't help you but I was chuffed haha. Quote Link to comment Share on other sites More sharing options...
