Themistoklidis Posted March 15, 2011 Report Share Posted March 15, 2011 Hey fellow bikers, I recently bought a pair of inspired element forks and i noticed that the headtube inner diameter is way smaller than my old forks(onza zoot)So i went to my lbs and showed them the forks.I was stunned when they told me that i cant find a starnut that small anywere in the greek bike market.There are no forks with such a small headtube hole diameter...What can i do?Can anyone tell me the size of the starnut required for this fork?Can i open the diameter so it can fit bigger starnuts?Or it will compromise the strenght of the forks? Quote Link to comment Share on other sites More sharing options...
isitafox Posted March 15, 2011 Report Share Posted March 15, 2011 Will a small starnut from Tartybikes not fit?? Quote Link to comment Share on other sites More sharing options...
Mikee Posted March 15, 2011 Report Share Posted March 15, 2011 (edited) Etiher the small or medium of these http://www.tartybikes.co.uk/headset_spares/tartybikes_star_nut/c57p10541.html will fit. Not sure which one exactly, but i'm sure someone will tell you for sure which one. EDIT: Just noticed your from Greece. If the postage price and time is not worth buying just a star nut on it's own, Then a headlock system like this could be a good solution if you can get one locally. Or you could make one from a long treaded bar with a top cap and nut on each end. Edited March 15, 2011 by Mikee Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted March 15, 2011 Report Share Posted March 15, 2011 What your after is a starnut for a 1" steerer tube. Im sure with a couple of phone calls to nearby bike shops you'll be able to track one down. I have one in my echo forks as it has a thick walled steerer tube aswell. Quote Link to comment Share on other sites More sharing options...
Themistoklidis Posted March 15, 2011 Author Report Share Posted March 15, 2011 Thank you all for your fast replys...I'll try fitting a 1 inch starnut,as every time i order from uk the currency is killing me!Thanks again for your replys... Quote Link to comment Share on other sites More sharing options...
Sam T Posted March 15, 2011 Report Share Posted March 15, 2011 If all else fails, run a headlock. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted March 15, 2011 Report Share Posted March 15, 2011 If all else fails, run a headlock. Duh i'd forgotten all about headlocks! Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 15, 2011 Report Share Posted March 15, 2011 A headlock might not work. The steerer tube might taper inside to the bottom, if it does it'll be too narrow at the bottom to fit a headlock. Quote Link to comment Share on other sites More sharing options...
Simpson Posted March 15, 2011 Report Share Posted March 15, 2011 Duh i'd forgotten all about headlocks! Ah f**k that, just get the smallest one you can find and angle grind it down to fit, done it loadsaaa times Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted March 15, 2011 Report Share Posted March 15, 2011 You've lost me there simpson were u refering to a headlock or starnut? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted March 16, 2011 Report Share Posted March 16, 2011 Star nut at a guess. Quote Link to comment Share on other sites More sharing options...
Ali C Posted March 16, 2011 Report Share Posted March 16, 2011 yeah, just grind down a starnut to fit. Quote Link to comment Share on other sites More sharing options...
John Shrewsbury Posted March 16, 2011 Report Share Posted March 16, 2011 yeah, just grind down a starnut to fit. Thats wat i did to fit an old pair of inspired forks. Grind a normal size starnut too the size so it will fit. Didnt you hav the screw in top cap that came with the forks? Quote Link to comment Share on other sites More sharing options...
Themistoklidis Posted March 17, 2011 Author Report Share Posted March 17, 2011 Thats wat i did to fit an old pair of inspired forks. Grind a normal size starnut too the size so it will fit. Didnt you hav the screw in top cap that came with the forks? The forks are the inspired element ones,so no threaded headtube I'll grind down some starnuts and see what happens... Quote Link to comment Share on other sites More sharing options...
Simpson Posted March 17, 2011 Report Share Posted March 17, 2011 Starnuts sorry, got excited, made myself look all pre-member-ish Quote Link to comment Share on other sites More sharing options...
