Hs33 Rim Brakes
Sangsta.
Hey all
I started riding about 3 years ago i was trialling for about 1 year then due to injury i stopped
but anyway i have HS33 brakes on my ONZA T-REX that where on it when i got it (it was a display model as well)
well now i can pull in the brake and the brakes hit but i can also bring in the lever after that
it the only hydraulic brake I've used so does it need to be bleed?
any info?
thanks for that link
i do not think i have a leak due to the not changing in quality over it life time
but i was wondering just how the brake should feel?
should the lever be really stiff from when the pads hit the rim or is there always some give
FYI i can pull it in about 1.5 cm after the pads touch
sorry if i wasn't clear enough before
thanks
SangSta.
hi,
You should use two syringes, one and the master cylinder and one at the caliper. Guessing also you need to use dot 5 brake oil.
it`s not dot 5 brake fluid, its mineral oil you need, either magura royal blood or lhm mineral oil that is used in citreon car suspension. you can get the lhm stuff from halfords ands its cheaper per litre than royal blood. don`t use dot 5 it will destroy your seals in the whole brake.
