Echo Sl Freewheel Fail?
monty221ti
hi there, i was in spain this weekend for the european comp but i got cancelled because of all the rain, i am now homa but i have a problem with my echo sl freewheel, it feels like ive lost some engagements or some of the pawls are stuck? its also very silent now? what can i do? oil it?
did you ride it in the rain and get water in it? Mine did this and became quieter and felt less responsive. Just oil it up and it should return to normal (Y)
  On 3/17/2011 at 9:47 AM, edwards 99 said:
get a tensile 96 click all the way never had problems with it :)
I think mud and water in any freewheel would f*ck it up, and I'm sure you will fine a lot more people who have had problems with Tensile freewheels than the two Echo ones.
  On 3/15/2011 at 3:34 PM, monty221ti said:
dont think i can buy gt85 here in denmark, but Wd40 is similar isnt it? it got some finish line today and it works fine now.
No!!!!
The only things that wd40 should be used for on a bike are removing seized bolts and polishing your frame.
WD40 is an oil based water disperser. GT85 is a teflon based thin lubricant.
WD40 will clean the crap out and let it run smoothly again but will dry up very quickly and the same thing will happen again (or worse the inside of the freewheel will be vulnerable to rust as whatever was in there will be removed by the WD40. GT85 will leave a thing lubricating coating that will stop rust and allow the parts to move more smoothly
  On 3/18/2011 at 12:53 PM, Azarathal said:
Wd40 is a degreaser with no lubricating properties.
Gt85 is a degreaser with lube built in.
was going to say that wd40 also drys which is no us as a lube. gt85 is a degreaser with teflon lube. works well with echo sl freewheel basically to stop it rusting and seizing as theres no grease whats so ever in them. (Y)
