bagre15 Posted March 14, 2011 Report Share Posted March 14, 2011 I'm with a little doubt about water bleeding. I'm want to bleed my echo TR brakes with water, but if I don't like the result can I bleed it with oil again? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 14, 2011 Report Share Posted March 14, 2011 you could give it a go, but theres a chance that the water will leak out of the slaves. If your adamant on running water, replace the echo slaves for magura slaves. And yes, you can rebleed with oil after with no problems. If you do it with a syringe just make sure that ALL of the water is pushed out and replaced by pure oil. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted March 14, 2011 Report Share Posted March 14, 2011 Only the first batch of Echo brakes had problems with leaking as far as i'm aware. I run one on the front without any issues, it was either Ali C or Mark that ran a set without problems too. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted March 14, 2011 Report Share Posted March 14, 2011 Maybe not so much from the master cylinder, but know a few people who's slaves have leaked on newer models Quote Link to comment Share on other sites More sharing options...
