Magura Slave Cylinders- Any Way To Service Them?
giantwhore
An thoughts on how to dismantle the cylinder to service it?
You *can* do it but it pretty much destroys the cylinder - you need a lot of force to remove and it usually mangles the pad clip or scores the piston surface itself. The piston is press-fitted onto a 'reverse' spring assembly (hard to explain)...
To lube the seals you need lube inside not outside. Take the slave off, blow it through with a track pump and fill it with oil (not wd40 or gt85, I mean proper oil), pump the piston in and out several times and you should have relubricated seals. Reassemble and bleed as normal - repeat when it gets sticky again or using a fluid with some sort of oil base. Im using machine coolant suds mixed 1:1 with water and it works well to keep my slaves from sticking.
Machine coolant, eh? Hmmm may have to try that. Thanks Forteh :)
