dannytrialskid Posted March 12, 2011 Report Share Posted March 12, 2011 Right, this has happened to me for a long time now and it is irritating. When I use to sidehop I did it landing to both wheels which looked really smooth etc... When I learnt wheelswapping whilst sidehopping I obviously used my front wheel first then swap to back. This happens to me when I sidehop now, and I just can't stop it. I land with my front and sort of bring the back over a bit. It looks tacky and I want to stop. I have tried and tried and can't figure how. Any suggestions? :/ Thanks in advance, Danny. Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted March 12, 2011 Report Share Posted March 12, 2011 I also do this, but the higher I can do it to front the higher I can do it to both wheels. I'd sort of say keep your weight more over the back, I think. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted March 12, 2011 Report Share Posted March 12, 2011 Pull the front up more. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted March 12, 2011 Author Report Share Posted March 12, 2011 (edited) Pull the front up more. Easier said then done. But I have tried and it does work sometimes. Edited March 12, 2011 by dannytrialskid Quote Link to comment Share on other sites More sharing options...
CalopS Posted March 12, 2011 Report Share Posted March 12, 2011 Try just going just to rear for a while. Maybe it will balence your sidehop technique out. Quote Link to comment Share on other sites More sharing options...
i like cunning stunts Posted March 12, 2011 Report Share Posted March 12, 2011 Does it really matter? I mean sometimes you are going to land the front first depending on a lot of factors sometimes it might be beneficial to go to front.. Look at beleays sidehop he always lands front wheel first.. Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted March 12, 2011 Report Share Posted March 12, 2011 Easier said then done. But I have tried and it does work sometimes. worked for me. if it does sometimes for you, try harder Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted March 13, 2011 Report Share Posted March 13, 2011 (edited) To front secures the move early on- TRASHZEN this = a good thing. Edited March 13, 2011 by Matt Vandart Quote Link to comment Share on other sites More sharing options...
pezza p Posted March 13, 2011 Report Share Posted March 13, 2011 Push the bike bait more to the side your side hoping Quote Link to comment Share on other sites More sharing options...
6ft-midget Posted March 13, 2011 Report Share Posted March 13, 2011 It may 'look tacky' but if you're still securing the height you want, does it really matter? Quote Link to comment Share on other sites More sharing options...
0zzy Posted March 13, 2011 Report Share Posted March 13, 2011 landing to front i think the hit rate of you not falling off is a lot higher because if it goes tits up its alot easier to land on pedal! 1 Quote Link to comment Share on other sites More sharing options...
bikeperson45 Posted March 13, 2011 Report Share Posted March 13, 2011 And also it makes sidehopping to thinner landings easier Quote Link to comment Share on other sites More sharing options...
alistair14 Posted March 13, 2011 Report Share Posted March 13, 2011 if you use your front brake to pull you up, try not to use it, it helped me land flat upto almost over bar hight means you dont rely on the front wheel pulling you up Quote Link to comment Share on other sites More sharing options...
Sam T Posted March 13, 2011 Report Share Posted March 13, 2011 if you use your front brake to pull you up, try not to use it, it helped me land flat upto almost over bar hight means you dont rely on the front wheel pulling you up This! Just don't touch your front brake at all. Your head will work Itself aroudn the fact you cant rely on it and therefore bringing you to two wheels. ( Or still going to front and realising what a silly thing it was ) Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted March 14, 2011 Report Share Posted March 14, 2011 (edited) Why do you want to change? I do this now, and ever since i started to do it all it has done is got me higher! EDIT: I think it got me higher because landing on the front allows you to lean forward to pull the back one up. Edited March 14, 2011 by Kieran Morrison Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted March 14, 2011 Report Share Posted March 14, 2011 Also if you are going to land to front you are effectively not having to jump so high. Remembering trials is all about finding the path of least resistance over an object, so with this in mind, to front wheel is all win. Quote Link to comment Share on other sites More sharing options...
alistair14 Posted March 14, 2011 Report Share Posted March 14, 2011 This! Just don't touch your front brake at all. Your head will work Itself aroudn the fact you cant rely on it and therefore bringing you to two wheels. ( Or still going to front and realising what a silly thing it was ) exactly this! just dont use your front brake ..at all! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 15, 2011 Report Share Posted March 15, 2011 take off a little further away from normal, and try and take off without using the back brake so much. Try and scoop the bike up more with the pedal stroke. At least thats what it feels like for me Quote Link to comment Share on other sites More sharing options...
