O-Ring Lubricant, Whats Safe To Use?
Alex Dark
Righto, my master pistons in my old quicksilver 2004 hs33s are starting to stick again. I've put brand new O-rings in both levers, so this has probably exacerbated it.
What kind of lube can I use? Apparently Vaseline eats away at the nitrile rubber, due to it being petroleum based. I know Silicone grease would be ideal, but id love to ride this weekend with nicely working smooth brakes!
To hand I have: Silicone spray , red lithium grease and general household items haha.
Anything safe to use from the above?
Cheers, Alex
Awesome! If one other person confirms this i'm going to be very happy :)
it doesn't make the ( nylon? ) pistons swell does it?
Not from when ive used it no, my dad is adamant that red lithium is actually red because its rubber specific, and he was in raf as a engineer for 12 years so hes probably right seeing as ive had no problems (Y)
