sstein Posted March 11, 2011 Report Share Posted March 11, 2011 link. anyone tried these? if so what they like on a grind? Quote Link to comment Share on other sites More sharing options...
dann2707 Posted March 11, 2011 Report Share Posted March 11, 2011 Here's my attempt at a review from the Pad Review thread. Pads: RED plazmatic take offs sold here Time used: 2-3 months Rim used: Front Atomz rim Grind: Yes - Stupidly light though, barely even a grind Ceraminc: No Brake used: V - Avid SD7 What is your opinion of a working brake: For the front brake I expect great hold for up to front moves but not really that much bite as I like a lot of modulation How do they compare to previous pads you have used: I had white echo on a HS33 which were poop, standard avid v pads which were ok-ish but the light grind killed them. Review: These brake pads are awesome. When ordering, you can opt for the soft or hard compund, I went for the hard compound as I was going to use a grind on the front, not knowing what these brake pads were to be like, but in actual fact I didn't even need a grind really. I presume a grind would make these bite instantly if you do wish so but I really wanted modulation for the front, not bite. They have a very high pitched squeak, compared to the deep honk produced by LGM's. For £13, in CNC backings you get such good value for money as generally speaking refill compounds are £15 anyway! I've recently been trying up to front moves and these have held be everytime. I haven't even noticed any dramatic wear life but then again that's expected on a near smooth rim. If you have a front vee and want good cheap pads, buy them! Hope that helps mate. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 11, 2011 Report Share Posted March 11, 2011 If your looking for good V pads, I used Phats...never looked back. Quote Link to comment Share on other sites More sharing options...
