sstein Posted March 11, 2011 Report Share Posted March 11, 2011 Hey guys, I have a revell trials frame and I was fed up of having to use a disc on it so I got some magura mounts and v brake mounts brazed on (brazed not welded to avoid affecting the strength of the metal). The brakes work fine but the seatstays flex out quite a bit, this does not affect my riding but i was wondering is it likely to damage the frame as the tubes are quite thin? do I need to run a booster to protect the frame? Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 11, 2011 Report Share Posted March 11, 2011 (edited) Yep, stick a booster on. flexing inevitably weakens the frame. Edited March 11, 2011 by Luke Dunstan Quote Link to comment Share on other sites More sharing options...
Ali C Posted March 11, 2011 Report Share Posted March 11, 2011 won't be so bad for a steel frame, put a booster on if you want the brake to be stiffer. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 11, 2011 Report Share Posted March 11, 2011 put a booster on it will help stop the frame flex and will make the brake work better Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted March 11, 2011 Report Share Posted March 11, 2011 You could get a 4 bolt booster bolted straight onto the mounts with some short M5 bolts. Would be proper stiff then! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 11, 2011 Report Share Posted March 11, 2011 I'd weld a magura evo style horseshoe booster on top, or make a nice one and weld/braze it on Quote Link to comment Share on other sites More sharing options...
sstein Posted March 11, 2011 Author Report Share Posted March 11, 2011 You could get a 4 bolt booster bolted straight onto the mounts with some short M5 bolts. Would be proper stiff then! Can only put on a two bolt because the lower bolts on the mounts are too wide, and i tried this, the problem is the v mounts are so much lower than the top maggie mounts Quote Link to comment Share on other sites More sharing options...
