Luke Dunstan Posted March 11, 2011 Report Share Posted March 11, 2011 After weighing my bike in at over 12kg last week, figured that most of the weight is on the back wheel. Really could do with some advice. At the moment I'm running the following on the rear... Maxxis Hi Roller Dual Ply - 998g Maxxis Downhill inner tube - 420g Echo TR Rear wheel - 1149g So that's 2.5kg on the wheel alone. What's available that would be suitable on the market, I've looked in to it a bit and found The Fat Albert which is a bit lighter, then go for a lighter inner tube maybe? What's the best rear inner tube for weight and strength? Cheers. Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 11, 2011 Report Share Posted March 11, 2011 You could try a swampthing and a thinner tube? I'm using that right now. With a dual ply tyre you don't really need a mighty tube as well. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 11, 2011 Author Report Share Posted March 11, 2011 You could try a swampthing and a thinner tube? I'm using that right now. With a dual ply tyre you don't really need a mighty tube as well. I'm not a weight watcher, but do you know the weight of a Swampthing? Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 11, 2011 Report Share Posted March 11, 2011 Not without taking it off to weigh. Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 11, 2011 Report Share Posted March 11, 2011 I used a Fat Albert and a normal tube and it was fine, pretty grippy too Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 11, 2011 Author Report Share Posted March 11, 2011 I used a Fat Albert and a normal tube and it was fine, pretty grippy too 2.25 or 2.4? I prefer bigger tyres, but will it make that much difference? Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 11, 2011 Report Share Posted March 11, 2011 2.25 or 2.4? I prefer bigger tyres, but will it make that much difference? 2.4" Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted March 11, 2011 Report Share Posted March 11, 2011 2.25 or 2.4? I prefer bigger tyres, but will it make that much difference? 2.35 swampthing is around 770 grams, stikys are about 20g lighter, only ever used a swampthing on the front and i love it! Quote Link to comment Share on other sites More sharing options...
siede. Posted March 12, 2011 Report Share Posted March 12, 2011 510g - Rhyno Lite Rim 490g - Hope Pro2Hub + sprocket, lockring, etc. 770g - Holyroller 2.4 170g - Schwalbe "Nr. 10" Tube -------------------- = under 2000g Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted March 12, 2011 Report Share Posted March 12, 2011 510g - Rhyno Lite Rim 490g - Hope Pro2Hub + sprocket, lockring, etc. 770g - Holyroller 2.4 170g - Schwalbe "Nr. 10" Tube -------------------- = under 2000g my 24" holy roller is 900g... Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted March 12, 2011 Report Share Posted March 12, 2011 Mine comes in at 720g, so 770 is a pretty good ballpark! Quote Link to comment Share on other sites More sharing options...
siede. Posted March 12, 2011 Report Share Posted March 12, 2011 my 24" holy roller is 900g... ... you must have used a shitty scale?! 900g is way to heavy... heavier then the 26" one. Quote Link to comment Share on other sites More sharing options...
