BradJohnson Posted March 10, 2011 Report Share Posted March 10, 2011 why does everyone seem to complain about magura black pads ? i have just bought the new hs11 with these pads and they work great, will i have problems with them in the future ? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted March 10, 2011 Report Share Posted March 10, 2011 Well its basically that there are much better pads out there. For a beginner they may be fine. But rest assured there are better pads out there should you find your brake slipping. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 10, 2011 Author Report Share Posted March 10, 2011 Well its basically that there are much better pads out there. For a beginner they may be fine. But rest assured there are better pads out there should you find your brake slipping. what pads would you recommend<---(probably spelled wrong) and at the moment my brakes are not slipping but they are only a week old so..... Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 10, 2011 Report Share Posted March 10, 2011 what pads would you recommend<---(probably spelled wrong) and at the moment my brakes are not slipping but they are only a week old so..... Click here, Quote Link to comment Share on other sites More sharing options...
N.Wood Posted March 10, 2011 Report Share Posted March 10, 2011 I use TNN LGMs on a grind and have found these to be the best available. If you don't want to grind yor rim some of the softer compound pads on tartybikes will work. Have a look through the pad reviews thread for ideas. Pretty much anything you can buy these days will be much better than magura blacks. Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 10, 2011 Author Report Share Posted March 10, 2011 I use TNN LGMs on a grind and have found these to be the best available. If you don't want to grind yor rim some of the softer compound pads on tartybikes will work. Have a look through the pad reviews thread for ideas. Pretty much anything you can buy these days will be much better than magura blacks. i did have a grind but after a few rides it polished off. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted March 10, 2011 Report Share Posted March 10, 2011 Well some sort of decent pads and a re-grind will make your brake alot better Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 10, 2011 Author Report Share Posted March 10, 2011 i had the grind when i was running a vee-brake so it could of been the useless pads i was using that smoothed the rim Quote Link to comment Share on other sites More sharing options...
onza1 Posted March 10, 2011 Report Share Posted March 10, 2011 I thought they alright at first then about a month of wear an they are shite got sum onza citrus ready to go on Quote Link to comment Share on other sites More sharing options...
Ross McArthur Posted March 10, 2011 Report Share Posted March 10, 2011 A lot of top riders will swear by Maguras own pads. Martyn Ashton runs Kool Stop pads and seems to think he doesn’t need anything better. Im pretty sure RJ ran blacks back in the days of his Echo. It gives a silent brake on a smooth rim which is great for certain things. Mr Macaskill was a magura pad user back in the days of his Ghz and they didn’t seem to hold him back. Anyway, what im trying to say is, you don’t have to worry about changing your pads at the moment if they are working fine for what you want to be doing. 1 Quote Link to comment Share on other sites More sharing options...
sstein Posted March 11, 2011 Report Share Posted March 11, 2011 Any pad works fine up to a certain point. The problem comes when you start trying to do bigger stuff and need a very good bite and hold to stop you from slipping out. Quote Link to comment Share on other sites More sharing options...
