What Chain Tensioner?
Josh - Sarge
Hi
I have been out riding today with mates and I was sidehoping onto a wall and came down and I snapped my sprung chain tensioner right off.
To my dismay I had to sit and watch for the rest of the day.
I dont want another one like this as the same thing will happen and i dont think a fixed one will be any better. My friends had snail cams and chain tugs. I now think one of these are the way to go. I have a 26" Diamond back Kubuki Mono. Which one would be best, pros and cons of both and which one can I get for around 25 pounds????
Thanks Josh.
Try and get your hands on a 74 kingz or make a spring tensioner. Or try a spoke.
I highly recommend the Echo tensioner. The only snag is that you need to run a Echo rear hub as the tensioner sits on the axle of the hub, this allows it to be tucked away nicely on the bike.
As seen below.
post-4095-0-04797900-1299615933_thumb.jp
Hi
Thanks Josh.
I broke my tensioner so i took 2 links out of the chain at first the chain was really tight but it loosend up after a few rides and now its perfect i dont need a tensioner.
try it if it doesn't work just put the links back in
