Gaz96 Posted March 8, 2011 Report Share Posted March 8, 2011 As the title says, just wandering how do you fit the freewheel? I know to grease the threads then do you just screw it onto the cranks with your hands or anything else needed to tighten it? Quote Link to comment Share on other sites More sharing options...
montyFORlife Posted March 8, 2011 Report Share Posted March 8, 2011 As the title says, just wandering how do you fit the freewheel? I know to grease the threads then do you just screw it onto the cranks with your hands or anything else needed to tighten it? a freewheel tool Quote Link to comment Share on other sites More sharing options...
dann2707 Posted March 8, 2011 Report Share Posted March 8, 2011 You don't need a tool Just put some anti sieze copper grease on the crank arm threads and screw the freewheel on as tight as you can. It will tighten up as you pedal. Quote Link to comment Share on other sites More sharing options...
Zetec S Posted March 8, 2011 Report Share Posted March 8, 2011 as dann said yeah.. From what I remember it's just like a normal thread (as in right to tighten, left to loosen) 1 Quote Link to comment Share on other sites More sharing options...
theom Posted March 8, 2011 Report Share Posted March 8, 2011 Will tighten up as you pedal. Quote Link to comment Share on other sites More sharing options...
stephenmx50 Posted March 9, 2011 Report Share Posted March 9, 2011 You will need a tool if you need to remove the old freewheel first, no tool require to fit a new one, a little grease on the thread screw it on as far as you can by hand, hold the brakes on and try to pedal it will tighten itself up! Be sure to check the black lock ring often, I had a tensile 60 the lock ring came loose and shredded all the inners! 1 Quote Link to comment Share on other sites More sharing options...
bella Posted March 9, 2011 Report Share Posted March 9, 2011 i jump on the pedals to tighten it. you dont want it to tighten on when ou go to gap.if you are struggling to get the old one off i found the best way to do it is put the arm in the vice and using an air gun or impact gun buzz it off they are on very tight its hard to get them off with a nuckle bar air guns are the way forward Quote Link to comment Share on other sites More sharing options...
Gaz96 Posted March 9, 2011 Author Report Share Posted March 9, 2011 No need to take an old one off, currently custom building a bike from scratch... thanks guys Quote Link to comment Share on other sites More sharing options...
ireson75 Posted March 9, 2011 Report Share Posted March 9, 2011 No need to take an old one off, currently custom building a bike from scratch... thanks guys Take the crank arm and freewheel to your local bike shop. I took mine there and they did it for free Quote Link to comment Share on other sites More sharing options...
