Cutting A Slot In Headtube
isitafox
I'm afraid the, err, operation will be undertaken whilst at work on nights this week so the tools available stretches only to a grinder (with assortment of discs), dremel (which I forgot to nick of my old man today!) and a drill with hole cutter (I'll have to either borrow or buy a hole cutter).
Not too fussed about immense neatness as if I do it it will be on my 07 python frame which is already a bit battered and only a toy as opposed to my 'proper' bike.
Need something to do at work this week so giving the frame a little makeover ala Adam Read.
Just use the hole saw to do as much of the work as possible, then the dremel to tidy it up a little and finally use a file to get a nice finish round the edges.
With regards to the size, take a look at current frames on the market. You'd hope they've done some calculations to get a rough idea of how much material can be left to hold onto the steerer. Make sure you're not going too close to the headset cups especially.
I want your job
