Luke_zoo Posted March 4, 2011 Report Share Posted March 4, 2011 I went out on it one weekend, wasnt runing to good 'had crap in carb' Cleened it out, went to go out it day after, started it up, didnt realize how much fuel I had left in it, so it started then cut out 3minets later... My mate says ive droped a piston ring? how can it do that? Quote Link to comment Share on other sites More sharing options...
Muel Posted March 4, 2011 Report Share Posted March 4, 2011 Put more petrol in. I presume by "dropping a ring" he actually means a ring has shattered? It's as close to impossible as it's possible to be. Just stick more petrol in and make it go. Quote Link to comment Share on other sites More sharing options...
kevind Posted March 4, 2011 Report Share Posted March 4, 2011 If it had dropped a ring you would hear horrible scrappy noises when you kicked her over and would have no compression. It sounds like she ran on a bowl full of fuel then cut out. Make sure there is fuel in the carb. Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted March 5, 2011 Author Report Share Posted March 5, 2011 Yeah I thought there was enuf fuel in just to kik it off but there wasnt in the end, then put fuel in, never ran after it Quote Link to comment Share on other sites More sharing options...
Si-man Posted March 5, 2011 Report Share Posted March 5, 2011 Check your jets no blocked again and check that your float bowl has actually filled up. Sometimes they don't Quote Link to comment Share on other sites More sharing options...
trialsmax04 Posted March 6, 2011 Report Share Posted March 6, 2011 Check you have replaced the floats in the bowl in the correct position. Its easy to put them in upside down meaning no fuel can flow into the bowl. And re-clean the jets. Running it low on fuel may have caused crap to get in from the bottom of the tank. Quote Link to comment Share on other sites More sharing options...
