Gaz96 Posted March 2, 2011 Report Share Posted March 2, 2011 (edited) Im needing a rear 24" wheel, not worried on weight atol more strength as I will only be riding street and was looking at these two choices... 1. Echo TR / SL Rear Disc 24" with 14T Sprocket 2. TartyBikes Single Wheelbuild, Inspired Pro Rim on My linkSapim/Halo 24" (Black) with Nipples with either one of these two hubs, what one would you recommend? Trialtech Sport Rear Hub or Echo TR Rear. The wheel build would cost about £115 and then a sprocket would be about an extra £20 so what would you guys reckon would be best for the money on strength wise... I do have a trialtech drilled front rim so would it look stupid with a drilled front rim and a undrilled rear rim, if so I wouldnt mind a drilled rim on the back then aslong as I dont lose to much strength... One thing which you'se might think is stupid is that I might be a bit pushed more towards the 2nd option due to black spokes but if option 1 is stronger then I would go for it Any help is appreiated, Thanks in advance Edited March 2, 2011 by Gaz96 Quote Link to comment Share on other sites More sharing options...
Gaz96 Posted March 3, 2011 Author Report Share Posted March 3, 2011 Surely someone can help? Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted March 4, 2011 Report Share Posted March 4, 2011 you can use those spokes for both?they are both good hubs,but trialtech is deffo stronger.rims are simmilar strenght,so buy what you like more... Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 4, 2011 Report Share Posted March 4, 2011 Pro tip: Make your topic titles more descriptive. Also, get the second one, but build it yourself, it's a good skill to have if you ride bikes. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted March 4, 2011 Report Share Posted March 4, 2011 Echo wheel build, I'm over 14 stone and by no means a light rider, and the wheel is still as true as the day I first got it. Quote Link to comment Share on other sites More sharing options...
