onza tpro Posted March 2, 2011 Report Share Posted March 2, 2011 Well I have got a Onza t-pro and my rear wheel bearings are shot and it has a buckle and I was wondering if bike shops will true a wheel that has a grind? Thanks Quote Link to comment Share on other sites More sharing options...
jonny-rolos Posted March 4, 2011 Report Share Posted March 4, 2011 yes most good bike shops will true a wheel. I think on a onza t-pro the barings ar open ruther than sealed there for the mud and wet ect can get in to them. You could just replace the barings but the will do the same thing in a short time. If it was me i would up grade the hub eather for a onza t master sealed hub or a sealed hub of your choice. http://www.tartybikes.co.uk/116mm_fixed_hubs/onza_tmaster_sealed_rear_hub/c62p102.html Quote Link to comment Share on other sites More sharing options...
Zetec S Posted March 4, 2011 Report Share Posted March 4, 2011 They shouldn't have a problem with it due to grinding not effecting spoke tension, for a guess. Worse they will say is 'No', and if it voids the wheel warranty (probably expired now anyway if you're on a t-pro) so be it, smooth rims just don't work as well for rear wheeled antics. Quote Link to comment Share on other sites More sharing options...
jamers Posted March 6, 2011 Report Share Posted March 6, 2011 Grinding the rim will not have any effect on your spoke tension, or make a difference when truing it. So they should have no trouble truing it for you. Bearings on the t-pro hubs are known for going. Its not if it goes, its when. the cones in the hub just die. I would suggest getting a new hub, even if its a basic t-master hub, it will last a lot longer. Quote Link to comment Share on other sites More sharing options...
T-comprider Posted March 9, 2011 Report Share Posted March 9, 2011 Sometimes its best not to true the wheel, because it may weaken it? and bearings are easy to get hold of Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted March 9, 2011 Report Share Posted March 9, 2011 Sometimes its best not to true the wheel, because it may weaken it? lol what ? Quote Link to comment Share on other sites More sharing options...
trials owns Posted March 9, 2011 Report Share Posted March 9, 2011 Sometimes its best not to true the wheel, because it may weaken it? and bearings are easy to get hold of where did you here that? thats one of the funnyiest things i have heard today! Quote Link to comment Share on other sites More sharing options...
