G_! Posted March 2, 2011 Report Share Posted March 2, 2011 hi, i bought a freewheel two months ago, the rockman 108, and this is doing "click" everyday...i know a bit is normal, but this is too much... can I do something for stop it? thanks Quote Link to comment Share on other sites More sharing options...
BradJohnson Posted March 2, 2011 Report Share Posted March 2, 2011 try tightening it up as much as possible. also i might not be the freewheel, bottom brackets some times make noises like that, oil it and tighten it up as mush as you can. hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted March 2, 2011 Report Share Posted March 2, 2011 my try all freewheel clicks all the time its scary shit ! Quote Link to comment Share on other sites More sharing options...
bella Posted March 2, 2011 Report Share Posted March 2, 2011 (edited) the rockman 108.9 is actually a try all if you scrach the black paint off the lock ring you will see the logo. the ring is welded so you cant easily tighten it. i am currentley trying to get mine appart as it feels like there is gravel in it. if you have ever taken a freewheel apart befor i suggest you get the lock ring off the back. it is welded so will be hard (i carfully cracked the welds after scoring them) and have a look whats going on may be one spring thats damaged or something simple. remover the faulty bit and put it back together, you may loose some engagment but a 96.8 instead of a 108.9 you wont notice the loss if you dont want to try this just buy a new one its not worth the risk mate and i cant ride properly when i have something like that in the back of my mind DO NOT over tighten the lock ring it wil cause you problems the freewheel will be stiff and then the lock ring wont stop coming loose Edited March 2, 2011 by bella Quote Link to comment Share on other sites More sharing options...
G_! Posted March 2, 2011 Author Report Share Posted March 2, 2011 ok, thanks to every one. i'll try to do something Quote Link to comment Share on other sites More sharing options...
monty221ti Posted March 2, 2011 Report Share Posted March 2, 2011 96.8? dont you mean 72.6? Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted March 2, 2011 Report Share Posted March 2, 2011 Rockman and Trialtech FFWs are exactly the same, pretty sure the TryAll one is too. My Trialtech was utter sh*te, skipped constantly, my friends one does too and have heard many bad stories about Rockman/TryAlls too. If it was me, i would just save up for a better one Quote Link to comment Share on other sites More sharing options...
