2 Boosters ?
matt.price
just wondering if anyone has tried this as my frame still flexes with a 4 bolt booster.
I was thinking putting a 2 bolt booster under the 4 bolt?
and another question , is a bit of flex good for the brake?
stupid idea?
good idea?
cheers matt
What frame is it? I still get a bit of flex on the back of mine but the brake works so thats good enough for me!
For the ultimate flex reducing setup I'd go for a TNN system with a trialtech 4 bolt on top. That would be immense!
don't want to spend £60 (is it?) . i already have a 2 bolt and 4 bolt ,
i just want to get it right first time on the bike , dont wanna take he bolts in and out .( just done a bit of a bodge on the threads ;) )
It is almost impossible to remove all flex, on any set-up there will still be a small amount of movement.
If the brake works then whats the issue? If your finding the brake performance isn't what you expect with one booster then there is a problem with brake setup. Bleed? pads hitting perfectly square? decent grind?
Edited by kyddie
