craigjames Posted February 26, 2011 Report Share Posted February 26, 2011 (edited) Something a little different. Only thing i don't like is the need for a half link as Koxx designed the frame for 17:14. Some new pics and a few new bits: Excuse the yellow floor, dad decided to paint the garage.... - Frame: Koxx Hydroxx 2 - Fork : Try-All Forxx - Stem: Try-All 3D Silver - Handlebar : TryAll Carbon - Front Brake: Hope Mono Trial 175mm Carbon blade. - Rear Brake: Magura HS33 2004 (Fresh Products blade, Coust pads from Mr Coustellier) - Brake Clamps: TryAll - Pedals: Wellgo MG-1 Ti - Cranks: Try-All ISIS 175mm, TryAll Symetric bash - Front Freewheel: Echo Sl - Rear Sprocket: Zhi 15t - Chain: KMC 610HX - Front Hub : Try-All CNC - Rear Hub: Zhi SL copy, Tryall cams - Rims: Rockman Hole rear, TryAll round hole front - Tyres: TryAll sticky lite Have a TryAll H 28h hub on a TryAll hole rim when I get some replacement spokes Geometry Wheelbase: 1084mm Chainstay Length: 381mm BB Rise: +55mm Should be around the 9.2/9.1KG mark, will be a little lighter with the new front wheel. Rides a lot nice with the Tryall bars and the new rear tyre. With the new tyre and clamps i've just about been able to lose the half link, although it's still bloody close. Considering a KMX K810 chain as it'll stretch a little more that the 610HX and offer a little more clearance? Edited May 27, 2011 by craigjames Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 26, 2011 Report Share Posted February 26, 2011 Looking good dude, shall be pinching a play on this next week for sure! Will be nice to get the half link in there and sort it out 1 Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted February 26, 2011 Report Share Posted February 26, 2011 Real tidy looking, wish i wasn't that broke so i could afford koxx. Quote Link to comment Share on other sites More sharing options...
I am ze best Posted February 26, 2011 Report Share Posted February 26, 2011 Looks really nice that one mate Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted February 26, 2011 Report Share Posted February 26, 2011 Something a little different. Only thing i don't like is the need for a half link as Koxx designed the frame for 17:14. WTF???????? Dude that bike is sweet, I especially like the cranks! I would be chucking a rear disc on that if it was my bike. Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted February 26, 2011 Report Share Posted February 26, 2011 Love the paint scheme on the TryAll forks, bike looks real tidy. Silver or Black Trialtech risers would be my personal choice over white. Quote Link to comment Share on other sites More sharing options...
i like cunning stunts Posted February 26, 2011 Report Share Posted February 26, 2011 I hear you i couldnt ride a frame that needs a half link which is why i got rid of my last one... Looks lovely though. Quote Link to comment Share on other sites More sharing options...
Paperclip Posted February 27, 2011 Report Share Posted February 27, 2011 Why do you need a half link? I'm running a standard chain on mine and I have no problems what so ever? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 27, 2011 Report Share Posted February 27, 2011 Why do you need a half link? I'm running a standard chain on mine and I have no problems what so ever? What gear ratio are you running? If the frame is designed around something like 17:14 then chances are 18:16/19:15 or some other seemingly random setups will be fine too Quote Link to comment Share on other sites More sharing options...
Paperclip Posted February 27, 2011 Report Share Posted February 27, 2011 What gear ratio are you running? If the frame is designed around something like 17:14 then chances are 18:16/19:15 or some other seemingly random setups will be fine too I ride 18-15 gear ratio. My chain line is perfect, My brake mounts line up perfect, so again explain why you need a halflink? What you NEED is a set of tryall cnc brake mounts, they have more adjustment then standard mounts so you can lift them higher to get the brake to line up........... Quote Link to comment Share on other sites More sharing options...
LauraPalmer Posted February 27, 2011 Report Share Posted February 27, 2011 (edited) I ride 18-15 gear ratio. My chain line is perfect, My brake mounts line up perfect, so again explain why you need a halflink? What you NEED is a set of tryall cnc brake mounts, they have more adjustment then standard mounts so you can lift them higher to get the brake to line up........... this... I have a hydroxx II lt and 18:15 works with TNN-clamps - wouldn´t work with clamps that have a shorter adjustment range; clamps with the plastic washers is another option(not the nicest one though...) edit: beauty btw Edited February 27, 2011 by wimmeretz Quote Link to comment Share on other sites More sharing options...
craigjames Posted February 27, 2011 Author Report Share Posted February 27, 2011 Why do you need a half link? I'm running a standard chain on mine and I have no problems what so ever? Because without a halflink the tyre was butted up against the brake booster and the pads were only halfway on the rim, so even with the try-all clamps I'd still have the tyre issue. Have you got the Hydroxx 2 with the rear disc mount or the Hydroxx LT without? Quote Link to comment Share on other sites More sharing options...
Paperclip Posted February 28, 2011 Report Share Posted February 28, 2011 Mine is the disc mount one, I run a tryall sticky tyre its a good 5mm off all way around and my tyres relatively new..... Quote Link to comment Share on other sites More sharing options...
craigjames Posted February 28, 2011 Author Report Share Posted February 28, 2011 Not a scooby then, as this tyre had no hope of going round! Chain? Are you running a Kool rather than a 610HX and it's stretched more? Quote Link to comment Share on other sites More sharing options...
Paperclip Posted February 28, 2011 Report Share Posted February 28, 2011 spanking new KHE, Its hardly streched at all yet, Or at least I have yet too move the wheel back from putting the chain on last week. Id hate too have too put a split link on my bike, especially if I did not have too, I know the split links the cheaper way out, but Id think about new clamps next thing I bought for that bike haha, Your bike Looks hot I'm Liking the forks they just set it off, Ill try get some pic's of mine up asap. happy riding Quote Link to comment Share on other sites More sharing options...
Mission Impossible Posted March 4, 2011 Report Share Posted March 4, 2011 Lovely bike :) Quote Link to comment Share on other sites More sharing options...
onzatrip Posted March 5, 2011 Report Share Posted March 5, 2011 Craig if you ran a maxxis in the rear im 99% sure that you dont need a hlaf link or anything. Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 5, 2011 Author Report Share Posted March 5, 2011 spanking new KHE, Its hardly streched at all yet, Or at least I have yet too move the wheel back from putting the chain on last week. Id hate too have too put a split link on my bike, especially if I did not have too, I know the split links the cheaper way out, but Id think about new clamps next thing I bought for that bike haha, Your bike Looks hot I'm Liking the forks they just set it off, Ill try get some pic's of mine up asap. happy riding The clamps would be ideal if i didn't have to buy a different tyre too. Might look into it if/when the half link dies or the tyre wears out. Glad you like it, the matching forks are nice. Lovely bike :) Cheers dude. Craig if you ran a maxxis in the rear im 99% sure that you dont need a hlaf link or anything. Fair point, never been a massive fan of maxxis tyres (apart from on a DH bike). Might look into it though. Quote Link to comment Share on other sites More sharing options...
Paperclip Posted March 6, 2011 Report Share Posted March 6, 2011 I honestly cant see why your tyre would not fit, there is honestly a good 9mm between my tyre and the booster and my tyres not that old either, Id recommend the try all clamps too anyone anyway just down too the fact there far easier too set up your brake as you dont have too square your cylinders up. Too prove my point even more so James Hyland runs a continental and has tyre clearance. f**k risking your good looks for £30, half links hurt people! Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 6, 2011 Author Report Share Posted March 6, 2011 I honestly cant see why your tyre would not fit, there is honestly a good 9mm between my tyre and the booster and my tyres not that old either, Id recommend the try all clamps too anyone anyway just down too the fact there far easier too set up your brake as you dont have too square your cylinders up. Too prove my point even more so James Hyland runs a continental and has tyre clearance. f**k risking your good looks for £30, half links hurt people! With the half link and the chain tight there is only 5-6mm of clearance between the frame and tyre. So I'd defo need a different tyre for it to clear. Maybe the Kenda tyres are extremely deep, but I swear I bought it because it was lower profile than the RubberQueen I ran before. Meh,we'll see; certainly can't afford new clamps and a tyre atm. Quote Link to comment Share on other sites More sharing options...
toyota200x Posted March 6, 2011 Report Share Posted March 6, 2011 Love: Rear brake lever & Rear King What tensioners are you using on the King? Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 6, 2011 Author Report Share Posted March 6, 2011 I'm not atm, I've got some I was going to use, but I've found with the fun bolts they aren't needed. Quote Link to comment Share on other sites More sharing options...
craigjames Posted May 27, 2011 Author Report Share Posted May 27, 2011 Few changes and some new pics. Ignore the yellow floor! Quote Link to comment Share on other sites More sharing options...
Chris Posted May 28, 2011 Report Share Posted May 28, 2011 was that a typo with the 175mm rotor? must be a 155mm rotor, as the fork on the hydroxx has this stupid mount... Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted May 28, 2011 Report Share Posted May 28, 2011 It's a 175mm rotor Quote Link to comment Share on other sites More sharing options...
