Canardweb Posted February 23, 2011 Report Share Posted February 23, 2011 (edited) Hello everybody, I intend to change some parts on the bike, and this includes cranks and freewheel. So I decided to go for the RockMan Lite Cranks. The thing is, I want to use an Echo SL 108 freewheel and I think I remember there was some problems fitting that frontwheel on these cranks. I might be wrong, but I think there was a thread about that problem. If someone can confirm it would be appreciated. Cheers Edited February 23, 2011 by Canardweb Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted February 23, 2011 Report Share Posted February 23, 2011 Not sure what the problem could be, in fact. The overall thickness of the Rockman freewheel its self is thicker than the SL Quote Link to comment Share on other sites More sharing options...
J.KYDD Posted February 23, 2011 Report Share Posted February 23, 2011 I'm running the rockman lite cranks, Echo sl freewheel and a trialtech bashring. You should be fine - i had no issues Quote Link to comment Share on other sites More sharing options...
smithy83 Posted February 23, 2011 Report Share Posted February 23, 2011 I'm running the rockman lite cranks, Echo sl freewheel and a trialtech bashring. You should be fine - i had no issues it will fit mate ,i was running same setup but with the titanium tt bash ring.freewheel may be fairly hard to screw on but just put plenty of lube on crank threads and youl have no probs.iv had two sets of rockman cranks and only had the tight thread issue with one set. Quote Link to comment Share on other sites More sharing options...
Maxx Posted February 23, 2011 Report Share Posted February 23, 2011 I think Rockman freewheel have also a problem because on Try-all cranks I couldn't screw my freewheel whereas others freewheels fit perfectly with Try-all cranks (try-all, echo, ...). Quote Link to comment Share on other sites More sharing options...
