davidbarr Posted February 22, 2011 Report Share Posted February 22, 2011 Is there any possible way to add disc mounts to your standard hub? I've had a look around online but can't seem to find anything and don't really know what to search for. May be impossible but thought it was worth asking. Cheers Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted February 22, 2011 Report Share Posted February 22, 2011 Not really, the only hub ive ever heard of having a removable disc mount is a Dmr Revolver, just get a new hub its alot easier than trying to do something that isn't really possible or that is possible but would proberly snap. Quote Link to comment Share on other sites More sharing options...
davidbarr Posted February 22, 2011 Author Report Share Posted February 22, 2011 Thanks milo, just wanted to make sure I guess. Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted February 22, 2011 Report Share Posted February 22, 2011 It would be a good idea for companies to make a front hub a removable disc mount people are forever swapping between disc, vee or magura. Quote Link to comment Share on other sites More sharing options...
t-comp-kierz Posted February 22, 2011 Report Share Posted February 22, 2011 (edited) If your rear hub has threads in both sides you can put a disk adaptor on, but it would probably come lose all the time. Edited February 22, 2011 by t-comp-kierz Quote Link to comment Share on other sites More sharing options...
davidbarr Posted February 22, 2011 Author Report Share Posted February 22, 2011 Thanks, I'll go check my hub. Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted February 22, 2011 Report Share Posted February 22, 2011 (edited) If your rear hub has threads in both sides you can put a dick adaptor on, but it would probably come lose all the time. Hehe I always do that. I don't think there are any front hubs with threads on either side but a rear would work but not very reliable Edited February 22, 2011 by Milo123 Quote Link to comment Share on other sites More sharing options...
Revolver Posted February 22, 2011 Report Share Posted February 22, 2011 It would be a good idea for companies to make a front hub a removable disc mount people are forever swapping between disc, vee or magura. Naah, cause a disc mount isn't exactly much weight, so the clever thing is to buy a disc hub. Quote Link to comment Share on other sites More sharing options...
rhythm_101 Posted February 23, 2011 Report Share Posted February 23, 2011 It would be a good idea for companies to make a front hub a removable disc mount people are forever swapping between disc, vee or magura. centrelock? as used on shimano, dt swiss and other highly know companies. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted February 23, 2011 Report Share Posted February 23, 2011 You can't really use a screw on disk adaptor for trials as it puts forces on it both ways. For commuting, fine. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted February 24, 2011 Report Share Posted February 24, 2011 It would be a good idea for companies to make a front hub a removable disc mount people are forever swapping between disc, vee or magura. But you could use just a normal disk hub for disks, vees and maguras? A certain mount hub isn't needed to use a rim brake. Quote Link to comment Share on other sites More sharing options...
Miles Mallinson Posted February 24, 2011 Report Share Posted February 24, 2011 centrelock? as used on shimano, dt swiss and other highly know companies. Yeh there are them, I never thought they were that good though the ridges sometimes got abit wrecked, its a good idea though. But you could use just a normal disk hub for disks, vees and maguras? A certain mount hub isn't needed to use a rim brake. Just a weight saving thing really. Quote Link to comment Share on other sites More sharing options...
