cunny12345 Posted February 20, 2011 Report Share Posted February 20, 2011 Hi, my slave cylinder piston is stuck out and is really slow so i would like to have some advice on how to get the piston out to clean it, thanks Matt. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 21, 2011 Report Share Posted February 21, 2011 Hi, my slave cylinder piston is stuck out and is really slow so i would like to have some advice on how to get the piston out to clean it, thanks Matt. Magura or Dengura? Sadly you can't. I clean mine with hot water out the kettle, few flushes (3/5) water is then clear and 9it's all working again. Old tooth brush to give a scrub around the piston as the lip seal can hold shiz and prevents the return. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 21, 2011 Report Share Posted February 21, 2011 I clean mine in pretty much the same way, but use fairy liquid and water for the outside and 3in1 to lube it Quote Link to comment Share on other sites More sharing options...
